Gearshift lever too close to 9" brake servo after upgrade
(In Topic #223947)
![cdgthreesalmons in the usergroup ‘Paid Member’ cdgthreesalmons in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![cdgthreesalmons in the usergroup ‘Old timer’ cdgthreesalmons in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![DSCN1263.JPG DSCN1263.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588066929/uploads/attachments/5ea7fa706fb24.jpg)
![DSCN1261.JPG DSCN1261.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588066913/uploads/attachments/5ea7fa601a402.jpg)
![DSCN1264.JPG DSCN1264.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588066950/uploads/attachments/5ea7fa8556ce0.jpg)
![DSCN1265.JPG DSCN1265.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588067100/uploads/attachments/5ea7fb1b93375.jpg)
I would make sure that you have the clearance between the relay lever (off the steering rack) to the selector.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2avatar2.jpg)
![paceman in the usergroup ‘Paid Member’ paceman in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![paceman in the usergroup ‘Old timer’ paceman in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
The lever itself won't hit the servo (as far as I've tested) but I did wonder about the relay rod as Briano has said. If it's an issue I may change to use rod end bearings, or trim the end of the rod so it doesn't scrape.
What mine does touch is one of the brake lines. The downside of fitting them with nothing else in the bay! Still I can bend them to sort that out!
Hopefully tomorrow I will be fitting some of the gear shift lever rods etc. Paceman, like you I have a brake pipe I formed before fitting the engine that the rod will catch! As you say - downside of prefitting these items - but I would not have wanted to do these jobs with the engine in place!! You say -"change to rod end bearings"?? - what do you mean please.
I will let you know what I find tomorrow.
Doesn't need to be a weighted rod. As you can see in the pic the rod attaches to the front not the back. I've not tested this out mind, but it's on my list of things I could do once the car is finished. You can also use small rose joint ends as well.
I suspect the bolts would foul the servo though.
I'll make my own for the fun of it at some point!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/greenman.jpg)
![borednow in the usergroup ‘Moderators’ borednow in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![borednow in the usergroup ‘Regional Hosts’ borednow in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![borednow in the usergroup ‘Local hero’ borednow in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
If you make the angles on the bracket into 90 degree angles it'll give you two advantages.
1, It'll miss the booster.
2, It'll act as a short shift upgrade.
Yep I know it sounds odd but by trapping the bracket in a vice and hitting it very hard with a large hammer you can bend the angles to 90 degrees and this helps reduce the throw a bit. It's not a massive difference but it definitely reduces the throw somewhat.
If you add the weighted rod (from a mk2/3) it also makes it feel more positive. There is a bit of cutting and welding involved if I remember correctly.
Ian
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Hs05-1.jpg)
![1985 in the usergroup ‘Paid Member’ 1985 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![1985 in the usergroup ‘Old timer’ 1985 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Current rides:
![IMG_20190803_123357.jpg IMG_20190803_123357.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1567341659/uploads/attachments/5d6bbc56973d7.jpg)
borednow said
There is another option that I didn't mention before as I know you're going for a full standard rebuld but….
Ian
Good idea that. If I had a spare shifter arm I'd try that. Don't want to snap the one I've got!
![IMG_20200429_141552.jpg IMG_20200429_141552.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588166336/uploads/attachments/5ea97ebfe5f8a.jpg)
Fairly close but not too close
Yours looks almost too straight, if try bending it forward slightly away from the servo but remove it and do it in a vice with hammer and heat
Current rides:
![Pistol in the usergroup ‘Paid Member’ Pistol in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Pistol in the usergroup ‘Old timer’ Pistol in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Thanks to boredmans advice I have bent the shift lever using heat/hammer/vice so that it now passes under the brake servo clearly. I had a spare lever to fiddle with - keeping the other as backup.
The problem with the rod/lever touching the servo.
![DSCN1272.JPG DSCN1272.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588264796/uploads/attachments/5eaaff5b5dad7.jpg)
Better now!
![DSCN1276.JPG DSCN1276.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588264801/uploads/attachments/5eaaff6096119.jpg)
![DSCN1277.JPG DSCN1277.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588264803/uploads/attachments/5eaaff62a0e96.jpg)
Original unaltered example next to altered version
![DSCN1274.JPG DSCN1274.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588264806/uploads/attachments/5eaaff65a4172.jpg)
![DSCN1275.JPG DSCN1275.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588264808/uploads/attachments/5eaaff67acf6a.jpg)
All seems to moving well. I will only know when I get the car up and running and can test the clutch/gearbox. Fingers crossed!
I can't understand how anyone who fits the larger servo and has the DX/020 5spd hasn't had to alter the shift lever. The engine/gearbox are fixed - the servo is fixed - no adjustments on either.???
It could be where the engine is sitting in the engine mounts. There is a bit of fore and aft movement on the gearbox mounts at the back and on the side but not a great deal. If you happen to have them both as far 'back' (ie towards the back of the car) as possible and everyone else has them as far forward as possible then this would mean the difference between hitting and not.
It was my brother in law that did that particular conversion (on two different cars) and he also found the short shift idea from somewhere. He did the belting of the arm way before trying to afix the un bent arm so I have no idea if his would also have fouled.
Weird innit?
Ian
