fuel pump operation
(In Topic #242660)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cool_flare.png)
![golfy1 in the usergroup ‘Local’ golfy1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Should the fuel pump start running when I turn on the ignition. Mine seems to be dead when I turn the ignition on, despite the wiring having been checked. I have just replaced the tank, so the system is effectively dry at present.
1800 gti tin top 1985 k-jetronic
There are known fuel pump relays that have wonky innards.
More on this at www.cabby-info.com
https://www.cabby-info.com/files/electrical/Relays_Kjetronic.pdf
You could remove the fuel pump relay and the relay just below it, turn the other relay around till it fits where the fuel pump relay should go, then when you switch on the ignition the fuel pump should start to run even if the car is not started so you can test the system.
A great help
P.S I'll keep the fire extinguisher handy
