Flashing temperature led.
(In Topic #216034)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160228_142150000_iOS.jpg)
![Pete M in the usergroup ‘Local’ Pete M in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
The resistance must be between 31K Ohm and 65K Ohm with correct COOLANT … 50/50 blend of
a/f to H20.
From this thread.
vanagonauts.com - This website is for sale! - vanagonauts Resources and Information.
technically on ce1 all you do is remove the 42/43 relay, but shorting the pins will do the same job.
for ce2 fusebox poverty spec mk2 without a header tank come with the level sender pins on the fusebox shorted together from the factory (no control relay on these, then logic is built into the clocks)
![:'(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cry.png)
Is it anything to do with the outside temperature being low?
EDIT … it's stopped now!!!
Last edit: by Pete M
