Fan speed 1 not working on 1982 VW Mk1 Rabbit (Golf Cabrio), but other speeds do
(In Topic #220094)
I am writing on behalf of my brother in the States, who is restoring an 82 Mk1 VW Rabbit Convertible (Golf Cabrio). The fan blower started working when he changed the relay–but it is not working on speed 1 (it does work on speeds 2, 3 and 4). When he selects speed setting 1, he hears a click somewhere under the bonnet but the fan doesn't turn.
He and I both would be very grateful for any thoughts you might have!
Tony
Last edit: by tonyperry12345
To be honest if it is working on 2-4 it is probably working on 1. It blows really gently on 1, and there are times when I don't feel air.
That is the ground pin that got burnt. I have had 4 Cabbies 89-93 and all have had that issue. I just use insulated male/female spad connectors and jumper around the pin. I also make Sure that the ground point is good, if not then I make a new ground to the firewall.
The switches are the second most common area.
I've attached some photos–would anyone be able to advise?
Thanks!
Tony
