Early (Passat?) steering wheel on later car?
(In Topic #221880)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/8AFB8E19-99C7-4C34-AE84-1D4A58C4609F.jpeg)
![shelltoes in the usergroup ‘Local’ shelltoes in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I want to fit an early steering wheel to my later '85 cab.
Both small spline so off to a flying start.
The problem is the way the horn connects.
Pictures speak a thousand words so:
Heres what i have on my car when the wheel is off;
![IMG_4437.jpg IMG_4437.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1565784591/uploads/attachments/5d53fa0c11adf.jpg)
Back of the stock wheel;
![IMG_4438.jpg IMG_4438.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1565784653/uploads/attachments/5d53fa4bdd691.jpg)
All stock stuff.
Here is what hope to make work;
![IMG_4439.jpg IMG_4439.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1565784705/uploads/attachments/5d53fa8020eee.jpg)
Of course those horn contact prong/spring things foul the current set up.
I have cable tied them up and out off the way so i could bolt it up.
![IMG_4450.jpg IMG_4450.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1565784798/uploads/attachments/5d53fadd3d669.jpg)
Not ideal.
Any thoughts?
Last edit: by shelltoes
![IMG_4446.jpg IMG_4446.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1565784940/uploads/attachments/5d53fb6b61472.jpg)
Anyone have a pic of how it works on them?
https://www.classic-vw.co.uk/steering-wheel-horn-ring-811419660a-audi-80-coupe-quattro-21691-p.asp
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/zender%20avatar.jpg)
![bacardincoke in the usergroup ‘Old timer’ bacardincoke in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I think it's made by Petri, you'll see similar, less dished wheels on Opel's, BMW's etc. of the same period.
Your hub also appears to be for the Passat, I doubt there'd be an easy way to convert it to Golf fitment, so you'll have to source a new hub.
Petri's unfortunately have an unusual bolt pattern.
I've had a quick look and you're possibly wanting hub number 1140, but I'm not that familiar with Petri's so do more research before committing.
Here's a link to a PDF that gives Petri hub numbers, might be a starting point…
http://www.der-graue.com/tuevundco/daten/kba70063.pdf
Google 'Petri 1140 lenkrad nabe', (German for steering wheel hub) for more info/images of what you need.
All bolted up with fully working horn.
As I thought the horn connect ring from an old T25 wheel was the answer.
Did a bit of cutting and grinding and just like a scout leader "beep repaired"
