door pillar removal
(In Topic #220594)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/645B6506-034D-4D04-962B-8133448D4448.jpeg)
![mcjjordan in the usergroup ‘Local’ mcjjordan in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
stripping down cabriolet door ready for paint but
1. how do i get the pillar out between quarter window & front window
2. i cant get mirrors off as they dont fold to get access to screws
Wiring jedi
Www.jvsautoelectrical.co.uk
1. If you remove the rubber seal/runner the glass runs along there might be a screw at the top and there is a couple of bolts in the door and a atthe bottom to hold it in place.
2. the mirror should fold, try spraying in some penetrating oil in the gap between the base and mirror frame it see if it moves, you will have to move the mirror to gain access to the 2 screw.
i got all the bolts/ screws out so its loose in the door but i cant get it out the door -only solution i see it to rotate it back & forth but id need to prise the gap open & that doesnt seem right .
Wiring jedi
Cabriolet 1/4 window (vent).
Remove the door card
Remove the inner and outer scraper.
Remove the main window.
Remove the 2 screws at the top of the wing, one in the rubber one under it.
Carefully shoot some lube on a scraper and Gingerly get it on the under side of the seal inside and out.
Remove the 1 or 2 lower screws on the Channel.
A couple of Palm smacks on the rear of the vent frame (open the window) will usually clear the vent out of the frame.
Once the window seal is clear of the metal, then you are going to have to rotate it to get it out of the door frame at the top as the lower screw mounts interfere with the removal out the Window gap which is why you have to rotate it.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/leech%20kr.jpg)
Regional Host NE
![nicci21paul in the usergroup ‘Paid Member’ nicci21paul in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![nicci21paul in the usergroup ‘Regional Hosts’ nicci21paul in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![nicci21paul in the usergroup ‘Local hero’ nicci21paul in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![1st.jpg 1st.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1554019908/uploads/attachments/5ca0764329168.jpg)
![2nd.jpg 2nd.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1554019912/uploads/attachments/5ca07646acf72.jpg)
![3rd.jpg 3rd.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1554019916/uploads/attachments/5ca0764b3352f.jpg)
