Door handle / Door catch adjustment
(In Topic #223837)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Image1587331339917.jpg)
![mk1newbie in the usergroup ‘Old timer’ mk1newbie in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I've got 3rd party exterior door handles fitted and the passenger side one when pressed doesn't quiet release the door catch enough to allow the door to open easily. Drivers side works perfect. Does anyone know if there is any adjustment on these, pfa.
![](https://uploads.tapatalk-cdn.com/20200420/88efbbe204f9e5bb6a9addcc80d0adde.jpg)
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
![cedar in the usergroup ‘Old timer’ cedar in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Draw a ring around it first.
![](https://uploads.tapatalk-cdn.com/20200420/c032374e89628b8a9e86cd6003f864ad.jpg)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/bonfire.png)
![Vic in the usergroup ‘Local’ Vic in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![O_o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blink.gif)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Briano1234 said
What does the striker pin on the door sill look like, as when it is maladjusted and missing the nylon collar, they can cause the latch to bind.
Agree the plastic collar always goes AWOL, wrap some insulation tape around it as a 'temporary' fix (that will prob end up a permanent fix)
If you do get a replacment be aware that there are a few different lengths, when fitted very careful and gently close the door, dont slam it and dent the door …..
