Clutch grating noise 91 clipper
(In Topic #223920)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/GOLF.jpg)
![Bruiser23 in the usergroup ‘Regular’ Bruiser23 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I have a grating noise coming from the clutch when pressed. When idle there is no noise….when fully dipped there is no noise. It's kind of just at the initial portion of the press. I have ordered some gear oil and plan on checking and replacing the oil when it arrives
With the engine idle it's fine. If I raise the arm of the clutch in the engine bay the noise appears
It's a 91 1.8 engine
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/greenman.jpg)
![borednow in the usergroup ‘Moderators’ borednow in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![borednow in the usergroup ‘Regional Hosts’ borednow in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![borednow in the usergroup ‘Local hero’ borednow in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
according to the reciepts from the previous owner, it looks like it has had a new clutch kit and a new clucth release bearing in 2015
This video shows slowly dipping and then releasing the clutch. The noise only happens during dipping and releasing of the clutch
Last edit: by Bruiser23
