clutch cable help
(In Topic #214501)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/horse.png)
![BAZ-GTI in the usergroup ‘Paid Member’ BAZ-GTI in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![BAZ-GTI in the usergroup ‘Old timer’ BAZ-GTI in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Ashton09 in the usergroup ‘Paid Member’ Ashton09 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Ashton09 in the usergroup ‘Local’ Ashton09 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I would not care if pedal bit higher or lower as long it's got little bit play
Loosen the locking nut on the cable at the gearbox end and screw the plastic bit at the end of the cable in or out till you get some free movement.
You can grab hold of the cable in the engine bay and there should be the 10mm of movement if you pull the cable up.
You do have the rubber bush underneath the plastic nut and metal of the gearbox and the cable is nice and straight about the gearbox?
Photo and Video Storage | Photobucket
I have a plastic clip which hold the cable in place.
How my cable runs around the engine.
http://s44.photobucket.com/user/markfrommark72mark1gls/media/Golf/IMG_7634_zpsslyv1dot.jpg.html
Hope you can click on the links and see the pictures??
