Cabby roof disconnect for respray?
(In Topic #213128)
1989 Cabby non power
Open the top half way and Secure it with a broom stick and a pair of vice-grips.
Remove the Plastic top corners and place in a baggie along with the 2 screws.
Remove both "C" pillar pig tail seals. (give you more room and a better view.
look for the cable nut between the outerskin and the headliner.
It is partially hidden by the strut pivot arm, which can be removed by taking out the 10mm bolt that holds it to the frame.
Hold the bolt end with a pair of pliers or long forceps.
Use a articulating 10mm speed or ratcheting wrench to loosen the nut, one the nut is easy to spin, then remove it and carefully remove the cable from the cable tray.
Now do the other side.
With the cable totally loose, you can carefully work it out of the cable tray buy gently tugging on the rear seam…. Remember the thing has been there for years, and the channel is probably got dirt and crud in it.
Now you can fold the top down, and tape it off or mask it off… The Cable tray is totally exposed.
Now if you want to totally remove it et:all then on cabby-info there is a how do I remove the top and frame instructions.
When going back, I would strongly urge suggest, DO IT EVEN, getting a new cable.
This should allow the hood material to be tucked inside the car papered and masked off, and plastic sheet placed over the hood.
If you need to repair areas and want to remove hood and frame completely etc.
Undo heated window wires and the hinges that hold the rear window frame in place.
open boot and prise the spikes down that hold the headliner in place under the parcel shelf supports.
Once the first paragraph at the top is done. You can access the bolts that hold the webbing straps into the corners of the car body, they're will also be 2 screws and cup washers that hold the headliner there.
Depending on set up manual or hydraulic power disconnect rams from frame.
Then there's the 8 bolts that hold the main hinge in place. IIRC 6 are 17 mm then 2 opposing are 13mm?
Lift the roof assembly off in to up position and replace in the open up position, much easier.
Thanks again guys, Spik and Vanessa the VW
