Buzzing noise
(In Topic #218356)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20151017_154027.jpg)
![chris130256 in the usergroup ‘Local’ chris130256 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Fuel pump issue?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/catgif.gif)
![jamie8v in the usergroup ‘Paid Member’ jamie8v in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![jamie8v in the usergroup ‘Old timer’ jamie8v in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Buzzing noise
“Does my 92 cabby gti have 2 fuel pumps ??
SORTED !! “
Sent from my iPhone using Tapatalk Pro
1992 1.8 8 valve Convertible GTI
2008 E93 335i N54 Twin Turbo
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
![Tiny convertible tin top.jpg Tiny convertible tin top.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1488411670/uploads/attachments/58b75c1120099.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/received_10212253851841257.jpeg)
![Kenneth Cartwright in the usergroup ‘Paid Member’ Kenneth Cartwright in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Kenneth Cartwright in the usergroup ‘Local hero’ Kenneth Cartwright in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
On the drive
Myvalver 89 GTi Grey mk2 16v
The issues are that the "in-tank" pump when it fails because of blockages in the inlet because the filter screen falls off, or that you run the car on less than 1/2 to 1/4 tank and just drop a couple of pounds of fuel in it… Burns it up, as it uses the fuel as a lubricant an a cooling agent to keep it running.
Other issue with the fuel pump is that the interconnect vibration dampner/hose gets weak and either holes itself or becomes so bad that the in-tank pump falls off and hits the bottom of the tank and vibrates like Hades on the tin.
You need 1/2 to 3/4 of a tank to open the inspection port under the seat, and I have a couple of tricks to keep the filter on as you worm the new pump in to the tank.
1984.5-1993 mk1 How to change your in-tank fuel pump | Volkswagen Owners Club Forum
Wow I type really really poorly some times… sorry for the breakage of the Queens English.
Last edit: by Briano1234
Cheers. Chris.
