Buzzing noise
(In Topic #218356)
Fuel pump issue?
Hi all, after bringing my 1989 cabby gti out of winter storage I found that it had a buzzing, whinny noise somewhere around the fuel tank. So it must be a fuel pump I reckon? The noise doesn't change pitch with various revs. However, pushing up on the fuel tank from under the car stops the whinning? Could this be the in tank pump? Cheers. Chris.
Buzzing noise
Hi this thread documents my my fuel pump journey, thought it might help. Just search …
“Does my 92 cabby gti have 2 fuel pumps ??
SORTED !! “
Sent from my iPhone using Tapatalk Pro
SORTED !! “
1992 1.8 8 valve Convertible GTI
2008 E93 335i N54 Twin Turbo
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
Thanks Jamie. I couldn't find any results when I searched for your thread? Any chance of a link please?
On the drive
Myvalver 89 GTi Grey mk2 16v
Thanks for the link. I've read it through and it is the in tank pump making the noise. I know this because the noise stopped when I disconnected it. Anyone got an answer to why the buzzing stops when I push up the petrol tank?
Because usually it is the main pump that whines because it has to overwork, and likes to complain.
The issues are that the "in-tank" pump when it fails because of blockages in the inlet because the filter screen falls off, or that you run the car on less than 1/2 to 1/4 tank and just drop a couple of pounds of fuel in it… Burns it up, as it uses the fuel as a lubricant an a cooling agent to keep it running.
Other issue with the fuel pump is that the interconnect vibration dampner/hose gets weak and either holes itself or becomes so bad that the in-tank pump falls off and hits the bottom of the tank and vibrates like Hades on the tin.
You need 1/2 to 3/4 of a tank to open the inspection port under the seat, and I have a couple of tricks to keep the filter on as you worm the new pump in to the tank.
1984.5-1993 mk1 How to change your in-tank fuel pump | Volkswagen Owners Club Forum
Wow I type really really poorly some times… sorry for the breakage of the Queens English.
Last edit: by Briano1234
I had already found your excellent write up on the in tank pump replacement. It's examples like yours that make the internet such a great invention. A big thank you for that. When I posted this thread, I hadn't discovered which pump was at fault? Now I know and I'll be using guide to change the intank pump.
Cheers. Chris.
Cheers. Chris.
