A few questions about my Mk1 Golf Clipper
(In Topic #223982)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/8.jpeg)
![gadget32 in the usergroup ‘Regular’ gadget32 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I am fairly new to the group, only bought this in October and put it straight in my warehouse undercover until now.
Just getting all the little bits sorted so she can come out into the sunshine next month.
Its my first Mk1 and I'm trying to find out things about it, can you help?
1. Can anyone tell me what wheels I have fitted as I have not seen them on any other car?
2. The rear wheel bearings feel loose, can they be tightened or do I need to replace them?
3. The steering is very heavy, I have hear from someone that the top mount spacers might be missing or is this just normal?
4. Is this the correct grill and lights for this car? I also have a single headlight grille. Which one is correct??
5. When I drove it home the front scuttle felt like it was all over the place, I've bought a K-bar, will this sort it or do I need anything else?
![IMG_3083.JPG IMG_3083.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588235800/uploads/attachments/5eaa8e1786276.jpg)
![IMG_3079.JPG IMG_3079.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1588236241/uploads/attachments/5eaa8fcd8be62.jpg)
1. I'm no good at wheels..
2. The rear wheel bearings are only just "nipped up" so VW fitted a split pin to stop the nut coming undone. If they are to tight you wreak the wheel bearing or to lose you will also wreak the bearing. I do mine up with the wheel on and so you can just feel no "in and out" play, it's the difference of a 2mm turn.
Always fit a new split pin if you adjust them.
3. Steering is heavy so don't turn the wheel without moving the car but it should lighten up once on the move and anything above 20 mph a finger and thumb should be able to turn the wheel.
4. The correct grill is on the car, 4 light grill.
5. Did you have the roof down when driving as they are floppy when it's down. You could have worn wishbone bushes? maybe have a look and check the rubber bushes or post up some pictures and we may be able to see something… K bar, bottom brace does help tighten up the steering.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/greenman.jpg)
![borednow in the usergroup ‘Moderators’ borednow in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![borednow in the usergroup ‘Regional Hosts’ borednow in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![borednow in the usergroup ‘Local hero’ borednow in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
1, The wheels are BBS RZ or they could be copies as lots of manufactures made copies. They were fitted to BMW's and VW's in the 90's.
2, What Mark said
3, true, but also if running wide tyres it makes it worse. Also if the camber and castor aren't correct it also gets heavier
4, What Mark says
5, It's an old convertible. They flex. A lot! Front K bar and top anti roll bar between the strut tops can help.
Looks like a nice one from here
Ian
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Hs05-1.jpg)
![1985 in the usergroup ‘Paid Member’ 1985 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![1985 in the usergroup ‘Old timer’ 1985 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Also the stereos can move about a fair bit so check for the rubber bung on the back of it
Current rides:
![IMG_20190803_123357.jpg IMG_20190803_123357.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1567341659/uploads/attachments/5d6bbc56973d7.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Front steering, depends what you are used to…. coming from a modern PAS equiped car (can you actually buy a new car without PAS?) they do feel heavy and very low geared. 1st corner I go around after a while not using them I end up on wrong side of the road. Make sure tyres are at correct pressure and geometry settings are correct. There is a ball race in the top mount that over the years get wet and rusts and can make things worse.
Can't say that the scuttle shake is that bad on mine but I did fit a K-bar that I came across cheap a few years ago. Suppose it depends how and where you drive. Cabrios are more for show than go.
Smart looking car btw.
I was really lucky to find such a clean car with original un-ripped interior.
I didnt know there was a ball race in the top mount, do you have a link to where I can buy these or a part number maybe?
If you have a finger gap between the metal top and rubber bush change them as they are at the end of there life.
I've tired most makes and Febi seem to be the best.
I don't think you can just buy the bearing, you can get the spacer sleeve on it's own or it comes in a kit.
Like this
https://www.ebay.co.uk/itm/VW-GOLF-MK1-SCIROCCO-CADDY-SHOCK-TOP-MOUNT-KITS-FEBI-BILSTEIN-GERMANY-PAIR-C165/221349752977?epid=5032902715&hash=item3389793091:g:TVMAAOxygPtSyqHv
Sleeve
https://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIO-SCIROCCO-CADDY-STRUT-SHOCK-TOP-MOUNT-SPACER-SLEEVE-x-2-C02/221277166691?epid=1627179830&hash=item3385259c63:g:-3cAAMXQtRxSJKQI
Post up a picture of your top mount and me may be able to tell if it's shot.
Other option is lift the front of the car off the ground and turn the steering wheel, could be your steering rack is worn/rough?
