tools, car ramps.
(In Topic #74911)
tools, car ramps.
Anyway, picked up my gear linkage kit and I have compared it to the haynes manual and think I have it sussed. To get two of the bushings I need to remove the nut to the ?selector shaft? which is right underneath.
So, I am making the most of my new driveway and and I have already bought a jack and some axle stands for my rear bearing replacement.
I get real nervous under cars, probably a sensible self preservation instinct! I have been thinking for this job maybe some ramps would be best, After all I don't need the wheels off.
So, anyone got any reccomendations, some of the ones I have seen look like I would have to take the spoiler off to drive up!
Peter.
1980 1600 GTI, daily driver.
Yep - My brother did that. The wheel spat the ramp backwards! Luckily the fact that the car had stiffer springs and adjustable Konis on full hardness saved the sill from sure death as the car rocked on two diagonally opposite wheels!crazyquiff said
Make sure the ramps are not in a slippery surface as One will break away and you'll drive right over the top 8O
My Build Thread
How much do these ramps cost? Never seen one for sale, but admittedly havn't been looking!
Owner of a Golf Driver 1.6 G Reg running
twin choke weber carb 32/34. More to come!
Peter.
The nice thing about them is they don't have "rungs" on them like some of the cheaper ones which can make getting the car on to them smoothly a bit of a nightmare.
Personally although there is the odd job that can be done with drive on ramps I think jacking it up and putting it on axle stands is hard to beat.
Otherwise you could always dig a pit in the middle of your new driveway :wink: .
Cheers,
Chris
You think I haven't thought of that! Got stuck on how I'd drain it though!
Peter.
Guest user
Peter.
easiest way would be to go a little deaper and have a sump and pump down the bottom, pretty sure that pits have been banned now though due to carbon monoxide poisoning
Peter.
If you knew someone who was a dab hand with a fairly heavy duty MIG welder I reckon you could put together a manual type ramp like the one I have. The design is very simple, and uses fairly cheap farm jacks at each corner for raising and lowering. I reckon if you fabbed it yourself you could probably produce one for a few hundred quid in raw materials.
Cheers,
Chris
Here are some of my manky offerings!
What a beast …
Ebay press….
…and slightly underpowered MIG…
