Won't start!
(In Topic #155514)
Just after new fuel filter, plugs and air filter. 1.8 GTI 8V 1992 sportline
I have a 1800 8V GTI sportline. It has been stood over the last 6months but fired up once in a while, with the battery also kept on a trickle charge when not in use.
Yesterday, I took it for an MOT. It fired up first time and I drove to the testing station, only to be told the Machine was 'down'. I told them i'd be back this morning and that's where things went wrong. With a bit of time on my hands yesterday afternoon I decided to give the car a little service. I put 4 new spark plugs in, changed the air filter and the fuel filter. Went to start it and it coughed a little, after a few attempts it started and i thought it had struggled because the filter would need to fill with fuel! Oh no! It had other ideas… It stalled and then struggled to start at all. Since then, it hasn't started without a big spray of 'easy start' although that only helped for a bit. Now it dies straight away.
Question: Is it the fuel pump? And would a fuel pump work intermittently before totally dying? Or is there anyway, I could have upset something when I did my little service. I've even tried putting the old filter back in! Putting the old plugs back in! Even though I did them one by one, I've double checked a injection wiring diagram…
It's now at a garage but I think i may do the work myself. Is there anything I should check for to determine if it's the fuel pump - there's a lot of pressure in the fuel filter!! If the pump was dead, would there be much pressure there?
I'm stumped!
Any pointers would be greatly appreciated.
Many thanks.
1992 Sportline Red
It could be coincidence but if it drove perfect there and back before you did service then perhaps it is something to go with that.
I would make sure all your HT leads are round the right way, that the rotor cap is on tight and arm, that all visable wires attached and nothing has been knocked off , make sure fuel filter is tight etc
trial and error a bit i suppose
Best of luck with finding the problem mate
someone with more knowleged will be along with a technical answer soon i hope :-)
1.8T CABBY
1.8T CABBY
1992 Sportline Red
Have you got it started yet?! What was the problem?
1992 Sportline Red
