takes ages to start
(In Topic #92356)
![justin-gti in the usergroup ‘Old timer’ justin-gti in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
takes ages to start
i have had my mk1 1.8 gti a wile now,and it has always took a few turns to start but from 2night after work i got in it and it tuck ages to start,i thought it was cause i was pritty low on petrol but i went and put some petrol in and it did the same i was left cranking for about 5mins and did the same when i got to my girlfriends
has any one had this problem???or no what the problem is???
thanks justin
thanks justin
mk1 golf gti in porsche ocen blue and polished porsche 7slots
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Does it need a good service? Plugs, leads, rotor arm, dizzy cap? If not done for a long time can be worth it and maybe make the difference?
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Does the fuel pump prime when you turn on the ignition [you should hear it whirr in to life] check this link .
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=10919
Member 125 - 2005
![mk1jim in the usergroup ‘Paid Member’ mk1jim in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![mk1jim in the usergroup ‘Local hero’ mk1jim in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
is it ticking over ok when it does finally start ? once you have started it and run it if you turn it of will it start straight away ? but then if you let it stand for a while and then try to start it will it take a while to start again ?
if yes to the above i would check the fuel injecters for leaking fuel out of the ends .
