Rusty filler neck in 1991 Cabriolet.
(In Topic #89604)
:? Having just bought my 1991 Cabriolet , I notice that the fuel filler neck has rusted and has a hole in it. I believe it is a fairly common problem in these. I am wondering where I can go about ordering a replacement and what is involved in replacing same. A friend has suggested that a replacement unit could be made up .
Seanie
Seanie
Seanie,
'Better to wear out than rust out'
Hi Seanie.
Its pretty hard to get hold of a cabbie filler neck nowadays. Normally you'd have to get one fabricated. The best way is to source a tintop filler neck and adjust that (I think it involves cutting some of the bottom of and using some rubber tubing). You should be able to get a filler neck from Crazyquiff at www.golfmk1.co.uk
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
I could be wrong, but GSF seem to list them
29320 FUEL FILLER NECK G1C >84 (>Ch.15E011290) 33.00
29320 FUEL FILLER NECK G1 >12/83 33.00
29321 FUEL FILLER NECK G1C 84> (Ch.15ZEK011291>) 96.00
the latter being gold plated
Looks good but have GSF a website ?
Seanie,
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
We got a filler neck for a 83 cabby from GSF in Norwich last year no probs. I would try gsf before fabricating.
Yorkshire Region Host
Mk1 Cabriolet 1500 (under resto)
Mk1 GTI
Mk1 GTI
Yeah would be easier than fabricating. Am wondering if the 29320 that someone mentioned earlier is the ordinary Golf . If so from what I gather this one needs to have some adjustments made. Do you know what number unit you ordered. ?
Seanie,
shawnee mate, despite the fact you haven't uploaded any photos of the new baby yet, I'm about to write a "how to" for absolute noobs on replacing this pipe, using a tintop pipe, i did it today and honestly, I am the least mechanical minded person you ever met(though i'm working on it!)
Check it…
hope u and cabby are good!
Check it…
'83 Black GTI Cab on BBS RAs - DreamBoat 3000'
Resto = http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=67552
Finally got round to getting time to take pics and do some uploading. However it seems there is a prob with uploading pics at present and the facility is removed. However I have the pics and will load when the system is back.
Seanie,
