Rear exhaust hanger strain
(In Topic #95090)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20200305_113915.jpg)
![Diesel-dubber in the usergroup ‘Local hero’ Diesel-dubber in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
A petty problem but just wondering :
Does anyone elses exhaust put a LOT of strain on the last rubber hanger at the back? The exhaust just seems to want to sit a lot lower than the hanger does! It's almost too hard to push the exhaust up high enough to put the hanger on! Luckily the hangers still last a while despite the strain and only cost 70 ish pence each…but still.
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
If you undo the last clamp [before the back box] and with the hanger attached twist the box in to the position you want , then tighten the clamp it holds the back box in position . The weight is then correctly taken by the two support straps at the last section .
The hanger then just acts as a 'hanger' not a support . If you see what i mean
Cheers…………….
Cheers…………….
:doh: Thanks
![cedar in the usergroup ‘Old timer’ cedar in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Try some genuine hangers from VW, they're dearer but better than the pattern ones.
