please help, petrol leaking everywhere
(In Topic #85670)
ok so its a 1.3 driver, nothing changed engine or fuel wise….took it for a drive, back box fell off so i drove it home, left it there, a day later it just started leakign fuel for no reason, and was coming from infront of the spare wheel well?? i assume the exhaust issues r unrelated but there u go..
As soon as i took the battery leads off, the problem begin to lessen until it eventually stopped, the tank still has plenty in it….
checked in the engine bay and a pipe that connects between the carb and somewhere in the middle of the block by the bulkhead had come off, put it back on took it for a drive again…same problem… got home, turned it off…fine, then workign on car for abotu 20 mins it starts going again
Its coming out of a small plastic pipe from the side of the tank, and infront of wheel well, i assume this is som\e type of overflow, is something blocked? what should i look for/fix
I cant find any useful info anywhere as its all for gti's (all injection and completely different)
Fuel is leaking a bit from the carb but not enough to worry about, just bcos its crap more than anything…
hope someone can help as it really is pouring out…
also found a bell shaped peice of rubber on my drive, ive seen it b4, that goes on the end of a pipe, i assume this just directs the fuel overflow as opposed to spraying all the underside of my car?
thanks for any comments or suggestions
thanks very much
Josh
thanks very much
Josh
ok so i traced the pipe back today, and it led to a gravit valve with pressure part, apparently thats what its called according to haynes, i also managed to break this part, does anyone know where i can get one, or is it a dealer job?
what wud b causing the fuel to reach here in the first place?
ta
Josh
ta
Josh
The bell shaped bit (VW part no 321 201 890) should go on the end of the small hose you mention hanging over the back off the tank. Not sure why fuel should come out of it, as you mention it's attached to gravity valve, but try reattaching the end and fitting a new gravity valve. Think you can still get the gravity valve from VW delaers - part no 161 201 753.
1983 1100 C
1983 1100 C
thanks for the offer, although if i can get one, im going to go for a new ones, make sure i eliminate this problem area…is this gravity valave the ONLY breather on carbed models? apart from the one that is leaking fuel of course.
im really really stuck with this problem, and haynes is no help whatsoever!
ta
Josh
ta
Josh
Have you fitted the new gravity valve or fixed the problem yet?
Have you seen this thread http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=20918 ? Got a diagram of the breather system you should have. Gravity valve is no 40 and pipe over the rear of the tank no 9. You could try removing all the breather hoses and checking for damage or blockages.
1983 1100 C
1983 1100 C
thanks for the reply mate, replaced the breather valve and it fixed the problem, cleaned it all uop painted it, new bolts n washers, seems to be fine now
