magnets to clean a fuel tank
(In Topic #79948)
heres a quick how to…
fit big magnet to the underneath, lowest point of tank beneath lifter pump
put loads of fuel in
drive around a bit
leave it for 12/24 hours
remove fuel lifter, under rear seat
remove big magnet
use a little magnet securely tied on to a piece of strong string to lift all the rust from your tank which will have gathered at the lowest point.
i used an old speaker magnet for the biggy
and a fish tank cleaner for the small one.
it works
rebuild in progress....
BODGER :mrgreen:
jobs a good un, and took minutes instead of 5/6 hours with a mate!!!!!
the tank was clean as you like, if id had seen rust inside the tank itself i would have probably flushed it.
bodgers a bit harsh
i reckon you just wish youd have thought of it eh!!!!!
Web Team
cabriaulait said
bodgers a bit harsh
Dont do jobs by Half - You'll Learn :roll:
Bin there done that! :mrgreen:
Enjoy it whilst it lasts.
:wink:
'how to remove rust from your fuel tank'
….. :roll:
Baz
P.S. I still have to take the fuel gauge sender unit out.
he hasnt stopped telling me
tis on another thread search it dude
cabriaulait said
douglove ll tell ya,
I'll have a butchers.
Baz
Years ago I had a clipper cab which had a seriously rusty filler neck… I replaced it after I found out about this being such a problem but not before it had clogged all the fuel lines and destroyed the carb as well! :cry:
Wish I'd had thought about that!
would have made cleaning the tank a million time easier!
As a point, could you permently run a magnet on your tank do you think? would make a great little pre filter.
bear in mind it wont pick up road dust etc.
its more as a damage limitation excercise.
