Injectors & Inserts - HELP NEEDED!!
Swapped my standard DX 8v head (off my '92 Mk1 Rivage GTI) with an early 80's Mk1 GTI head that has been port and polished etc. Only trouble is the injector inserts differ between heads and my original injectors wont fit into the inserts from the early 80's Mk1 GTI head.
Has anyone run into this problem, what injetors do I need to fit the early inserts? Any info would be appreciated!!!
Matt
Have you got the inserts from your original head, these should fit your new one. If you dont have them, you can get them from VW. Only a couple of quid each.
