Idle on Pieburg 2e Carb
(In Topic #88033)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Image1457988692652.jpg)
![sherriff276 in the usergroup ‘Local’ sherriff276 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Does anyone know how to adjust the idle on this carb, I've fitted a K&N bolt-on item, and now its idling at about 1000RPM, when its warmed up. Is this right or am I being paranoid! :dontknow:
LHD 1.3 Cabriolet GL
Nobody got one of these carbs then? Oh well :dontknow:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
These carbs a notorious for playing up. Fiddling with the settings is bound to lead to heartache. Put the old filter back.
If you are really keen there is a large nut at the back you can wind in and out but you are supposed to set the CO at teh same time by adjusting something else.
THANK YOU!
Heres a BUT……….its starts and idles better with the K&N although its @1000rpm when warm
