how to richen and set the mixture - need to know asap
(In Topic #91449)
I was hoping to ahve time before the MOT to get my haynes manual and set the engine up properly but i have got a MOT slot on thurs and I will need to set the mixture up tonight, The engines only 600miles or so old since the rebuild and the idle was set at just over 1000rpm, since i have lowered this by winding out the stop on the top of the throttle the idle has dropped to just over 900rpm, but the car is now a pita to start and requires throttle top get it going, aftera few blips it will settle down nicely.
I have a CO2 machine so thats not a prob but hows best to go about doing this, i assume with a hot engine, what co levels should i be looking for and how do i adjust the mixture
many thanks
Karl.
many thanks
Karl.
i believe its done by tweeking the recess screw on the airbox using a longreach allen key. much less than a quater of a turn each time, till its right.
HTH
HTH
I have now set the mixture with my little machine, after mush faffing and waiting the initial reading was about 7% CO2, so i have now leaned this out to about 3%-3.5% as i dont have a haynes manual yet to give me the proper figure, it seems to be running fine but it hasnt cured my starting problem, (see my other post for this problem)
Join the 3mm allen key club
