help on fuel tank hose
(In Topic #89993)
hi having took out my fuel tank over a year ago ,i bought all new now struggling to get everything fitted,tank is in and filler neck tho the hose that connect to one another,is going up on a slight angle,will this be ok when i fill up with petrol??as dont look right,also new tank has hose filler neck on tank is pointing upwards not downwards any pics thanks
oh ive done the fuel tank starpes up tight,if i losen them will that be enough to drop the tank,so the hose would be straight??
Tank straps should be done up tight, there's no adjustment in them. Is the tank positioned correctly, any breather/fuel hoses trapped above tank?
1983 1100 C
1983 1100 C
hi no pipes above tank,everything is tight but hose connecting fuel tank to the fuel filler neck is going upto tank onto a slight angle
