HELP mk1 golf gti cab metering head needed,
(In Topic #133936)
to start off i had a running problems, after the auto choke switched off she wouldnt tick over unless throttle was applied and then sounded like it had a miss untill you floored the throttle, i could smell fuel coming from the exhaust so after going on a few forums i had a mess with the fuel mixture ( 3mm alan key on the metering head) got it to tick over at 1500 rmp and sounded smooth, not happy with that i had 2 mess again :redfaced: and now she starts for 2 seconds then cuts out even with throttle, i think ive broke the metering head ? any ideas or a metering head i can buy from someone would be great thanks D
the important thing is you put it back together properly, its very fiddly to do it right. if not this could explain why its playing up! its almost impossible to do without stripping the air flap down completely
