Help! fueling problems..
(In Topic #90474)
![Thegreg in the usergroup ‘Local’ Thegreg in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
all the plugs are dry. when you turn the key and the fuel pump primes the engine will sometimes just try to fire but wont run. i took out the plugs and syringed a little fuel into each cylinder, it fired up straight away and ran all of 2 seconds till it burnt it all
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
so theres no fuel coming through! the pump is noisy, fair loud buzzing sound from it, but only when you turn the key on and off.
so is it duff?
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
Re: Help! fueling problems..
Thegreg said
if its not one thing its another, just as i get to the bottom of the ignition fault (turned out to be the switch) and got the car running, came out today and it wont start :cry:
all the plugs are dry. when you turn the key and the fuel pump primes the engine will sometimes just try to fire but wont run. i took out the plugs and syringed a little fuel into each cylinder, it fired up straight away and ran all of 2 seconds till it burnt it all![]()
so is it duff?
Greg 8)
Ideally, connect a fuel pressure gauge and see what the system pressure is when its cranking. Are you sure the fuel pump is running when the car is turning over (start position on ignition switch)?
the other day when i had it running i could hear the fuel pump going when the engine ran, but now it doesnt even run :dontknow:
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
Thegreg said
the fuel pump goes for about a 2 second run before the engine is cranked over, i cannot hear it going when the engine is turning, then when i stop cranking and turn the key back it comes on again like it does before hand.
Greg 8)
You need to check if the fuel pump is running during cranking. Rig up a voltmeter if needs be, or lean over and get your head close to it while turning the key.
i pulled one of the injectors out and nothing comes out of it when the engine is being cranked over
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
![adibateman in the usergroup ‘Local’ adibateman in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
well i took it back seeing as i sorted the problem out, plus it didnt fit anyway, so im not going back there for one!
anywhere else do them?
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
