GTi Cutting Out!!!
GTi Cutting Out!!!
My '83 Gti keeps cutting out, runs ok for about 8 miles then just dies.
The previous owner thought it was the fuel pump relay, so i hav been reseating the relays to try an restart. This doesn't always cure the problem tho.
I think it may be a mk2 fuse box i have (not sure if the Gti has the same as a mk2 or not?). Does anyone know which relay is the fuel pump relay?
Or any other faults which may be causing the car to cut out?  :banghead:
Any help would be great
Cheers, Craig.
hi yes this has been covered loads of times, but the fuse box on the 1.8 is the same as the mk2 upto 1990, the relay is numbered 2 and is the upper left large relay on the fuse box, but u will feel it click when u turn the car over.
it may well be the pump that has failed. or less likely the coil breaking down.
Regards Volkswarren
X2 1983 A REG EW CAMPAIGN In WHITE(Awaiting full rebuild solid body) :thumbs: & T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only)  or an A reg Lhasa Green or White Gti to restore, also consider  Black, Red or Blue, Also Golf Driver Project Wanted anything considered WHY
Mk1 Golf GTI 83 Y reg in Lhasa green
Rear disc conversion
Lowered 20mm
14" Campaign Pirrelli P Slots
Thanks Guys,
I'll check these out this week, Fingers crossed its a simple fix
Craig
