GTi Cutting Out!!!
(In Topic #79566)
![cam80 in the usergroup ‘Regular’ cam80 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
GTi Cutting Out!!!
My '83 Gti keeps cutting out, runs ok for about 8 miles then just dies.
The previous owner thought it was the fuel pump relay, so i hav been reseating the relays to try an restart. This doesn't always cure the problem tho.
I think it may be a mk2 fuse box i have (not sure if the Gti has the same as a mk2 or not?). Does anyone know which relay is the fuel pump relay?
Or any other faults which may be causing the car to cut out?
Any help would be great
Cheers, Craig.
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
Cheers, Craig.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AvatarUploadedByTapatalk1451991667.jpg)
![volkswarren in the usergroup ‘Paid Member’ volkswarren in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![volkswarren in the usergroup ‘Local hero’ volkswarren in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
hi yes this has been covered loads of times, but the fuse box on the 1.8 is the same as the mk2 upto 1990, the relay is numbered 2 and is the upper left large relay on the fuse box, but u will feel it click when u turn the car over.
it may well be the pump that has failed. or less likely the coil breaking down.
Regards Volkswarren
![Avatar](https://i248.photobucket.com/albums/gg178/allsorts5/Mk1OCAvatar.jpg)
![allsorts in the usergroup ‘Local’ allsorts in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Check out this thread, hope it helps!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=10029&highlight=
Mk1 Golf GTI 83 Y reg in Lhasa green
Rear disc conversion
Lowered 20mm
14" Campaign Pirrelli P Slots
Lowered 20mm
Thanks Guys,
I'll check these out this week, Fingers crossed its a simple fix
Craig
Craig
