fuel pump for DIY efi
(In Topic #77137)
![matt-mk1 in the usergroup ‘Local’ matt-mk1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
im planning on using bike throttle bodies with my carb tank, plan is to use a performance pump to get fuel to swirl tank and then a injection pump from swirl tank to throttle bodies. anybody recomend a injection pump from any car that would be good for this application? trying to do this on a budget so looking for OE pumps to start with.
thanks.
matt
thanks.
matt
![yeha in the usergroup ‘Old timer’ yeha in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
GM pumps from cavaliers are crud tolerant, cheap and supply at 3 bar.
thanks,il keep that in mind,im thinking bout just using the pump accumaltor and filter from a mk2 16v not as that would mean i wudnt hav to fork out for an after marker swirl opt.
thanks for the advice tho.
matt
matt
