Fuel lines dimensions
(In Topic #76827)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/100x100.jpg)
![c11rgd in the usergroup ‘Local’ c11rgd in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
anyone know the exact diemnsion of both the Supply line and Return lines for the gti
ide like to know the diamater of the pipe
the fittings on either end and the lengths
please help
please help
Birmingham
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
You can buy them "New" from http://www.golfmk1.co.uk
If not look at
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=902&highlight=fuel+lines
Tells you size somewhere . Crazyquiff on here has done the ground work for you and at the price you can't go wrong . Saves a lot of leg work .
Good luck ……….
If not look at
Good luck ……….
![Avatar](https://i2.photobucket.com/albums/y12/PhillT1/Animation4.gif)
![PhillTMK1GTI in the usergroup ‘Local hero’ PhillTMK1GTI in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Crazyquiff's also got them pre made I believe, might be a pig to get posted though
![onelazygit in the usergroup ‘Regular’ onelazygit in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Crazy Quiff sells the original fuel lines but these come bent to shape and cannot really be couriered.
However he also sells flexible braided fuel lines that can be couriered and are the correct length and come with the correct fittings.
I bought some just before Christmas when my fuel line rusted through. I purchased both fuel and return lines and have no real mechanical experience but it took me just 6 hours to fit them and they are brilliant. They are the exact dimension of the brackets that hold the pipes in place so you literally undo each end of the pipes, open the brackets, remove the old pipes and run the new ones.
Cannot speak more highly of them.
If you want anymore info from me just ask.
Ian
Ian
My life is an endless battle against maturity.
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.golfmk1.co.uk%2Fimages%2FExLink%2FAvatar.jpg)
![crazyquiff in the usergroup ‘Paid Member’ crazyquiff in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![crazyquiff in the usergroup ‘Paid Advertisers’ crazyquiff in the usergroup ‘Paid Advertisers’](https://vwgolfmk1.org.uk/themes/default/images_custom/PaidAdvertiserIcon.png)
![crazyquiff in the usergroup ‘Local hero’ crazyquiff in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Ta for the comments guys.
Yes - I have both flexi (not on the website yet
ops
and preformed solid lines in stock as well as the two rear flexi pipes.
I also have fuel pipes in solid and flexi form for standard carb cars as well as 16v coversions
Gimme a shout if you need anything.
Rich
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
Rich
d
its not that i know you have them was wondering instead if the supply line which is 3 parts could be made so its just one large one instead so wanted to knoe the diemnsions and same for the return which is 2 want to make it one!
Birmingham
I see what you mean now
If you have a look at my old post above i did exactly what you want but i have routed my lines differently to the original so can not give accurate dimensions sorry . However you can either measure against your old ones or use the rope method then measure it for the total length required . Yeah i no what your thinking
Cheers………
3
well i know th eguy at www.listers.co.uk
motorsport division here in birmingham. so wanted to see what hed price me!
Birmingham
