Floor pan getting VERY hot from Exhaust
(In Topic #74575)
![Avatar](https://i2.photobucket.com/albums/y12/PhillT1/Animation4.gif)
![PhillTMK1GTI in the usergroup ‘Local hero’ PhillTMK1GTI in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
is it common for the floor pan (mainly by the seat runners/hand brake) to get VERY hot from the exhaust? :dontknow:
![Avatar](https://img.photobucket.com/albums/v502/dubboy/76%20GTI/Driveravatar2.jpg)
Life Member
![dubboy in the usergroup ‘Local hero’ dubboy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![dubboy in the usergroup ‘Moderators’ dubboy in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![dubboy in the usergroup ‘Paid Member’ dubboy in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![tallpete in the usergroup ‘Old timer’ tallpete in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Check your heat shields still intact!
LOL, maybe you need to do a spacewalk and check the foam tiles.
Buzz.
1980 1600 GTI, daily driver.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AVATAR.jpg)
![AL_Mk1 in the usergroup ‘Local hero’ AL_Mk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Heat shield? What heat shield… :roll:
I'm pretty positive I don't have one. Would a "driver" have had one fitted as standard or was it just the Gti's?
My Build Thread
there's a heat shield by the fuel tank, rubber gear linkage boot, gear linkage support bracket/mount thingy and the obvious at the front.. just seems the rest of the area is a bit exposed :dontknow:
![Carbs4ever in the usergroup ‘Old timer’ Carbs4ever in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
wrap it if its a worry - but shouldn't do any harm… ok if your carpet's smoking wrap it
![tomo320 in the usergroup ‘Old timer’ tomo320 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
phil is the centre bit of exhaust lined up m8? turning it left to right will move it to and from body, are all the rubbers on your exhaust etc? the only important heatshield is one on tank,
good luck chap,
paul
good luck chap,
paul
![andunp in the usergroup ‘Local’ andunp in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
just timk of it as under floor heatin!!!!!!
costs a bomb in houses!!!!! so you should think yourself lucky.
think the exhaust mounts are knackered as it's sitting a little to one side
![Avatar](https://i8.photobucket.com/albums/a43/lowmk1/sfdh-1-1.jpg)
![lowmk1 in the usergroup ‘Local’ lowmk1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
are there any alternatives to the metal heat sheild? as mine rattles against the exhaust all the time and theres nowt i can do about it, its driving me mad
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
1272 driver with a magic tree!!
ps. sorry for thread hijack :mrgreen:
if the exhaust is rattling against the heatshield I suspect it's not in the right position (exhaust and/or heatshield).. have you tried bending the shield away?
yep bent it, pulled it, hammerd…still rattles…i just turn the music up so i cant hear it…
yep exhaust it tight as, doesnt move about alot and is std(i think) where it meats the heat sheild.
Can i just rip it off and cover the rubber with some sort of heatcover thingamajig
Life Member
