been messing...
(In Topic #96414)
![butler in the usergroup ‘Local’ butler in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
been messing...
:dontknow: been messing with the adjustment on the metering head and now the car wont start.. :dontknow: took the plugs out and they were full of fuel.. which way do i wind it to lean it up…? the mechanic who messed it up in the first place said that he sets them up by winding it shut then opening it up by one and half turns…? :dontknow:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Got Haynes manual? I think it tells you how to check adjustment etc?
To get round this, I have a little loom and switch I connect to the 5th injector. Then you can 'wind' the metering head mixture to lean, and using various flicks of the switch, manually control (approximately) the air/fuel mixture so you can at least make the car start and run while trying to get some kind of sensible adjustment back onto it.
Rich = clockwise.
Rich = clockwise.
have got it running but it sounds like its missing and then wont idle...?
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
butler said
have got it running but it sounds like its missing and then wont idle…?![]()
Could be rich or lean - you need a gas analyser of wideband to check.
i`ll just have to keep trying small adjustments as i`ve not got an analyser, its booked into a garage to sort it out but not till the 27th and i`ll need to drive it there..!
got it running and its going really well,still going to get it tuned thanks for the advice..
