Starting problem - please help!
(In Topic #79785)
Just tried to start my car and although the ignition lights come on and the fuel pump is going, the car won't turn over at all and there is no click or sound from the starter motor.
I have checked the battery and that is sound. How can you check whether it is the solinoid or the actual ignition switch, or could it be something else entirely?
Glad for any help you can offer.
Ali.
So many dubs so little time, so much rust
1983 mars red 1800GTi on ATS cups
G60'd, schrick cam, chipped, 70mm pulley, pace charge cooler, rolling road 182bhp 250Nm of torque, 14.50 quarter mile.
Crazy_Ivan said
if aint even turning over mate will be a prob with the starter motor. or starter circuit.
I'd agree with that, however are you sure your battery is ok? I've had snags starting in the past and wilst the battery may seem ok unless it's got plenty of juice you can get nothing out of the starter. Have you got another you can use to test or a battery charger?
Ian
'89 Clipper Auto and '92 GTI Cabby
Starting probs
Any one replaced these before ? it looks tricky to seperate and reconect the key hole mechanics to the electric base.
Thanks again Ali
