Starter or Solenoid?
(In Topic #84341)
![AliCabrio in the usergroup ‘Local’ AliCabrio in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
On turning the ignition key the solenoid seems to clunk, but the starter does not turn at all. The battery seems fine.
Anyone else had this?
The car is a 1985 Cabrio (MK1 shell, DX coded 8V engine).
Just when you think it's all sorted……another thing goes kaput.
Although having replaced;
head gasket,
Valve stem seals
injector seals
radiator,
water pump,
coolant hoses,
vacuum/vent hoses,
fuel filter,
oil filter,
distributor cap,
spark plugs
alternator wiring
I shouldn't be too surprised when the starter conks out.
:roll:
Ali Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
I never bother to strip the solenoid off the starter, just replace the starter inc solenoid, or have the original one reconditioned.
I'm going to dis-assemble the starter and solenoid, just to see if there's an obvious fault.
Then it'll probably be time to reach for the plastic :roll:
Cheers for the swift reply Paul
Ali Cabrio
Seat Covers
Scratches
Leaky roof
Seat Covers
Scratches
Leaky roof
![woZa in the usergroup ‘Old timer’ woZa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Michael in the usergroup ‘Local’ Michael in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Symptom : Lights stay bright and plunger in solenoid switch is pulled when operating the starter.
Test: Disconnect battery cable from terminal 30 at starting motor and connect it to terminal stud of connector (contact blade). If the starting motor operates, the contacts of the solenoid switch are worn or dirty
Solution: clean conatcts and/or replace solenoid switch
Thanks to Volkswagen AG for this extract from VW Workshop Manual
MP
see
Starter Problems sorted
Just as the weather turns nasty I have to do some work on the car…. :roll:
thanks for the help all
Ali Cabrio
Seat Covers
Scratches
Leaky roof
Seat Covers
Scratches
Leaky roof
