rear widow wiper not working
(In Topic #81480)
Hi my rear wiper won't work though the water jet does and rear window heater.
Are these motors fixable or should I look for another?
con
con
I am having the same problem. Unplug the connector on the rear wiper, get a multimeter and get someone to operate the rear wiper and see if there is a current getting through to the connector. If there is then the motor is at fualt and will need replacing. If there isn't then you need to work your way back to the fusebox and check connections and fuses.
HTH
HTH
