New heater fan - fitting?
All,
I have tried a new switch and a new resistor pack - but still, fan ONLY works in position 3, and even then it sounds rough. Not only that, when I turn it to posn 3, it sucks a LOT of voltage, so I think the fan is stuffed.
G&S sell new ones, but do I have to take the dash off to fit? I want to avoid this if possible!
Yeh, unfortunately the dash has to come off to remove and refit it.
______________________________________________
I'm sure I've done it from scuttle side, removing the wiper mech first. Its tight and fiddly but 100 times better than removing the dash.
Pretty sure you can get to it from the scuttle too...
Megasquirted 1981 Silver 1600 GTI Daily Driver
Still Restoring...
Yeah just had to remove the lower sections of the dash and center console, then undo the four screws that hold the heater onto the scuttle panel, its a pig of a job mind you !!! :banghead:
G60
Re: New heater fan - fitting?
bytor said
All,
Hi Bytor, could you check your messages please mate as i've been trying to contact you!! :wink:
See you at the shows!!
Hi Paul,
PM sent!
 :wink:
