New heater fan - fitting?
(In Topic #83206)
![bytor in the usergroup ‘Local’ bytor in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
All,
I have tried a new switch and a new resistor pack - but still, fan ONLY works in position 3, and even then it sounds rough. Not only that, when I turn it to posn 3, it sucks a LOT of voltage, so I think the fan is stuffed.
G&S sell new ones, but do I have to take the dash off to fit? I want to avoid this if possible!
![MatCashmore in the usergroup ‘Local’ MatCashmore in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Yeh, unfortunately the dash has to come off to remove and refit it.
______________________________________________
![](https://i123.photobucket.com/albums/o319/MatCash/blackgti012.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I'm sure I've done it from scuttle side, removing the wiper mech first. Its tight and fiddly but 100 times better than removing the dash.
![woZa in the usergroup ‘Old timer’ woZa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Pretty sure you can get to it from the scuttle too...
![andy77 in the usergroup ‘Paid Member’ andy77 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![andy77 in the usergroup ‘Regional Hosts’ andy77 in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![andy77 in the usergroup ‘Old timer’ andy77 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Yeah just had to remove the lower sections of the dash and center console, then undo the four screws that hold the heater onto the scuttle panel, its a pig of a job mind you !!!
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
G60
![Avatar]([IMG]http://img.photobucket.com/albums/v170/valverpaul/mk1sig2.jpg[/IMG])
![8Valverpaul in the usergroup ‘Local’ 8Valverpaul in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Re: New heater fan - fitting?
bytor said
All,
Hi Bytor, could you check your messages please mate as i've been trying to contact you!! :wink:
![](https://img.photobucket.com/albums/v170/valverpaul/mk1sig2.jpg)
See you at the shows!!
Hi Paul,
PM sent!
:wink:
PM sent!
:wink:
