New battery keeps on dying!
(In Topic #81118)
![TheMarkedOne in the usergroup ‘Local’ TheMarkedOne in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Do i need a new alternator or starter motor guys?
Any advice would be great.
Cheers.
![Avatar](https://i38.photobucket.com/albums/e109/MARSREDGTI/DSC02081.jpg)
![marsredgti in the usergroup ‘Old timer’ marsredgti in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
![](https://i38.photobucket.com/albums/e109/MARSREDGTI/marsredgti.jpg)
Ok....
![tallpete in the usergroup ‘Old timer’ tallpete in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
The alternator you should be able to test by putting a voltmeter accross it with the engine running, think it's supposed to put out 13 or 14V. Haynes manual should have more on this test.
http://www.btinternet.com/~adrian_beaumont/camper/part7.htm
Found this for a camper but you get the drift!
Short circuits need some logical searching. Remove battery earth lead then move it towards the battery post and it will probably spark. Remove the fuse for clock and try again, still sparking? got an alarm? remove the fuse and try again.
Basically things like clocks and alarms are always live, everything else pretty much be off when the ignition is off, so if you have a spark that shows there is still a circuit somehere. If you keep removing fuses you will find where the short is.
My old radio used to drain a battery in days!
Peter.
1980 1600 GTI, daily driver.
Kool....
Cheers.
Ez all....
Cheers.
Does anyone have any fo sale?
Fixed.
Now my fuel pump relay fuse keeps blowing each time i start the car.
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
![mcscrew in the usergroup ‘Local hero’ mcscrew in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Also, did you replace the starter motor with a standard Mk1 jobbie?
My new problem is that the battery light flickers.
I have changed my battery and alternator.
Any ideas?
Thnx
