mk1 golf blue dash bulbs? help
(In Topic #87156)
![Avatar]([IMG]http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg[/IMG])
![sim0n_parker in the usergroup ‘Old timer’ sim0n_parker in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
im after some blue dash bulbs for my dash to match my blue stereo,
can anyone help me out in locating some as ive bought a few sets now and they dont fit.
?? anyone help?? and also do you have to remove the green film?
i always have the last laugh ![;)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wink.png)
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Image1457988692652.jpg)
![sherriff276 in the usergroup ‘Local’ sherriff276 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
check this out, well worth a look
http://www.m-99.co.uk/Car_Neon_LED_Lighting/Dashboard_LED_Bulbs/dashboard_led_bulbs.html
LHD 1.3 Cabriolet GL
![Mr_modnaR in the usergroup ‘Regular’ Mr_modnaR in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
as my golf's only got two of those bulbs in the clocks, i found that mod to be a little dark, i eventually ended up cutting the PCB from a 40cm long LED brakelight down to fit, and that works lovely!
hope this helps.
hmm true as i will have to remove the green filter aswell.
thing is them bulbs are not the correct bulbs to fit the clocks even though it states they are.
simon
simon
<a href="
yes i had that problem too, but managed to fit the LEDs into the OEM bulb holders IIRC.
![mclannahan in the usergroup ‘Local’ mclannahan in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
simon
http://forums.vwvortex.com/zerothread?id=1448346
HTH!
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
yes to fit them into the oe bulb hlders you would have to solder them in as they are solderd.
simon
simon
<a href="
