Inner spots... help!
Hi there
My campaign's inner spot lights have mysteriously stopped working!
I have no clue whats happend, you could write what I know about electricals on the backof a stamp. The main lights all seem fine.
Any ideas as to whats gone wrong/ how I can fix it? In laymans terms if possible!  :wink:
Checked fuze ? Checked switch ? Start with the simple things electrics usually are
Cheers………
as above and also check the bulbs!! its not unlike both to blow at the same time! tis the law of sod :? , other than that check your main beam switch is getting a good contact on the steering columb and stalk, could be it needs some contact cleaner sprayed down the gap
thanks for the replies guys…
Went out today to sort it, rolled him out of the garage, tested bulb (one is very hard to get to so didnt test that one, thought id see if it was deffo not a bulb problem first).
The bulb was fine, so went to halfords and bought loads of 10 amp fuses, then went through checking them…. they were all fine.
At this point I was sure I would have to call out an electrician, and my dad remineded me to check everything else was still working as I'd been fiddling with the fuses. Went through checking the other lights, radio etc… then checked the fog light. Well dont I feel stupid!! There are three settings on the fog rocker switch:
1.rear fog off, front spots off
2.rear fog off, front spots ON! (when the main headlights are on)
3.rear fog on only
Doh! I have now moved the rocker switch to the middle setting and my spots now go on with my headlights as they used to. To say I feel a little silly is putting  it mildly!! Am dead chuffed its nothing major though  8)
thanks again
Chris
