Horn
Horn
Hey
Just recently bought my MK1 golf, and there is a third party stearing wheel on it. When i press the horn it makes a very quite kind of 'tut' noise and the lights dim in the car! i need a horn lol! is this an earth issue, where is my horn?
Any help greatfully recieved.
1983 MK1 Golf GTI - G60 Conversion
Is your s a Gti?
Do you have twin horns?
Crazyquiff's Mk1 Golf Parts Emporium
www.golfmk1.co.uk - you know you want to….
well this is where it gets confusing. It was a gti, its had a g60 conversion.
I havent had a proper look for the horn yet, as it doesnt work it makes it harder to locate lol! What do i do when ive found it?
Just seen your other posts - It is a Gti and most likely has twin horns.  If it has your problem is a loom one.  The horns draw a high current which is used to heat the loom which drops the voltage causing the horns to fail and your lights dim.
Use a secondary relay near the battery and make up a mimi loom to run the horns.  Or replace the appropriate loom wires.
Rich
OK, this kind of makes sense to me, and also confuses me. So i will wait till weekend, stare at the car for a while, have a drink then tackle the problem! May need to draw myself a diagram! thanks again!
Locate the horn relay and then use the switch feed to this to run a replacement realy as sugested above. You can then run the direct feed to this relay from the battery (again as sugested). This allows you to use the normal horn push button without having to go into and behind your dash.
Horns are located under the front valence on the passengers side of your car. They are right at the front and real easy to get at. Just run a new supply from your new realy to this and you will be laughing… ;)
Far too many toys…
…and a big smiley face!! :D
Or try using just one horn  :wink:
Even better, I like simple! Top tip ! :D
Far too many toys…
Make sure the earth wire at the bottom of the steering colum is in good nick aswell
Owner of:
1988 VW Caddy 1.6
www.vwcaddy.com
