Horn troubles! :doh:
(In Topic #75243)
Does anyone know of this problem and/or how to sort it?
:doh:
The dual horns take a lot of power and the wires deteriorate. i've the same problem with my Black campaign. I'm going to fit a relay controlled by the deteriorated wire as the low current will be OK and will not heat the wire. This is a bit over kill as the horn is relay controlled anyway! The proper way to do it is to replace the bad wires and use the original relay only.
Rich
Theres a couple of connectors right at the horn, I pulled them off in turn and gave them a good clean. All really full of crap.
Jobs a goodun.
Like Rich says probably a bad circuit and needs full voltage to make it work, therefore if you have the lights on it's enough of a drain to stop it working.
My rear wipers are the same, haven't got to the bottom of that one yet…
Peter.
1980 1600 GTI, daily driver.
Life Member
The earth wire on the steering rack is a good call to but you need an extra elbow half way down your forearm to get to the fixing!!!
Dan
I had the relay replaced, which fixed the problem, until today that is…..
Bum…
what now?
