Getting to my speedo/rev counter + stuff!
(In Topic #80041)
![junglist in the usergroup ‘Old timer’ junglist in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
The clear plastic thats on the front of my speedo/rev counter has 2 tabs, which are used to secure it. One of the said tabs has snapped off, so now my speedo sits on the wonk, which is really annoying!
Firstly, can you get the see-thru plastic bit, or is it all integrated?
Secondly how do i get to the speedo to take it out… Hairyarse said i go thru the heater matrix and stereo, but how?! Im assuming i take the nobs off the heater etc, does it then slide out?!
Cheers in advance!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
To take clocks themselves apart I think you can only do from the rear, remove (carefully!) the blue membrane first! 8O
Hope that helps?
I've temporarily managed to level the clocks up using some cardboard, but hopefully over the weekend i will find a more permanent solution!
Is the see through bit seperat does anyone know?
