gear change indicator?
(In Topic #72607)
![psparrow in the usergroup ‘Regular’ psparrow in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
where is it?
i have a bottom with 1 and 2 on….what does it do?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
If you mean 'button' not 'bottom'!! Then this is the switch for MFA (it's the one in the top right corner). on position 1 it is current readings - i.e. current time travelled, current MPG etc. Position 2 is total readings since the battery was last disconnected/system re-set so would give total hours driven in car, total MPG over that time period.
Ref your other post on the MFA not working, can be a number of issues. Do any of the functions on it work?
mfa
the mfa does not work at all
![lhasa in the usergroup ‘Old timer’ lhasa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
mfa
also where should the pipe be? there is an outlet on the guages but no pipe….i presume it comes off the inlet manifold somewhere?
wire
Paul
wire
Paul
