Electric roof question. Can it be done?
(In Topic #125332)
surely its just an isolator somewhere but i have no idea really.
anyone done this or no how?
thanks
T
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
You would ideally run a fuse inline, cant comment on what size fuse, but I would guess 20-25amps as the roof will draw alot of current.
***PM for all your powder coating needs***
Website Manager
shamstar said
Hi mate, if you take the switch out from the centre console, you will see a red wire that once tested will go live once ignition is in 1st position….this wire can be traced to the fusebox to a long thin plug with only one wire on it….cut this and run it to the perm live on the fusebox aux terminals….you will need a crimping tool and a crimp or two….halfords sell them.
Surely doing that would make it think the ignition was on all the time, so that it'd never work?
~Madferret
Mk1 1457cc 5door GX '83
Sorry dude, same wire, except it will go off when switched to 1st position….same wire on same block…I confused myself when I wrote that first…
Loads of ways to skin a cat mate…good luck with it.
1. Put key in ignition, but don't turn ignition on.
2. Press roof button in centre consol, roof lowers or raises.
3. Turn ignition on, roof doesn't work.
I'm no electrical genius but this is how i'm thinking, the switch must have 2 live feeds from the ignition. 1. for when the key is in the ignition 2. for when the ignition is on.
So there is 2 options for changing how the roof works:
A. Have the roof perminatly live so that you don't need the key to raise/lower the roof.
or
B. The roof can raise/lower only when the key is in the ignition but able to so when the ignition is on/engine is running.
I'm leaning more towards B as I don't like the fact that the roof would perminantly live. So if I do as SHAMSTAR suggests and trace the black wire from the switch to the fusebox and swap it on to perminant live (with in line fuse), would this then be option B above?
Cheers for help, confused bob. :dontknow:
Back of roof switch
This is the red wire that goes to the roof switch
And heres where it plugged in to my fuse box
So I crimped on an in line fuse holder, from Maplin £1.99, and connected it to here on my fuse box:
However, all this does is remove the need for the key to be in the ignition to work the roof. I still can't raise/lower the roof when the engine is running
What have I done wrong or what do I need to do to make the roof work when the engine is running?
Website Manager
Take a look at this pic, it is from the boot of the mrs cabby.
Those two connectors you see at the front were disconnected when we got it, one stops the roof going up and the other down with the ignition on !! There looks to be a diode in each connector. They were actually disconnected because one of the relays had a intermittent shorting fault.
Last edit: by lhasadreams
now im a sparky so i can see how this can work, but my question is WHY? why would VW put these 2 thru-connectors in the first place and does it have an affect on anything else, (i cant see it but its just too easy!)
if something is ture good to be true ………. u know the rest!!
Ideas????
Website Manager
if it works on 2…….
mines a k plate so maybe diff 2 yours?? but i think they would all be the same, shit they only made it over 2-3 years!
red and green wires either side of each thruway?
i second the need 4 a wiring diagram.
but i think we have answered the original post, or at least for 66% of peeps
