Dash lights
(In Topic #91493)
![skinmonkey in the usergroup ‘Newbie’ skinmonkey in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Dash lights
Hi,
I have no lights on my dash
all the fuses are good and intact, so i can only assume the bulb/bulbs are gone.
Can anyone tell me how to easily change these without ripping the whole dash out?
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
![mk1john in the usergroup ‘Local hero’ mk1john in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
if all dash lights are out it would suggest there is a deeper rooted problem, unless all bulbs have gone at once.
there are various screws along by the clocks and heater etc that remove the clock fascia so you have access to the heater controls, clocks, and all switches, so you don't need to remove the full dash
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
![Avatar](https://i1038.photobucket.com/albums/a466/timmyturtle/RIMG0324-1.jpg)
![Timmyturtle in the usergroup ‘Local’ Timmyturtle in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
There are 3 bulbs for the dash lights,they twist out easily usually
Check the reostat is turned up on your headlight switch first
![1stgolf in the usergroup ‘Old timer’ 1stgolf in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Check the reostat is turned up on your headlight switch first![]()
ha ha i had that problem on my mk2 and it ended up to be the reostat was turned right down lololol
<img>
