Coil wiring early small block
(In Topic #106344)
![ashleymk1 in the usergroup ‘Regular’ ashleymk1 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Coil has the follwing 4 connections
1
15
I have the following wiring
Ballast
Green wire from condensor
red/black wire
lilac/grey & black wire joined.
someone match them up for me
![yeha in the usergroup ‘Old timer’ yeha in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Madferret in the usergroup ‘Old timer’ Madferret in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
you have +12 to Ballast through that to the + on the coil (if that makes sense)
Basically the green switches the - rail which is what collapse the coil and makes the spark. The purple/black is the feed for the rev counter.
~Madferret
Mk1 1457cc 5door GX '83
