Alternator
(In Topic #84431)
![dannyboyblue in the usergroup ‘Old timer’ dannyboyblue in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Alternator
Morning all,
I need to replace the alternator on my 86 1.8 Gti cabbie. I think the current one is 55amp but is it worth going up to 65amp? I only say this as I have quite a powerful stereo on board and I want a better charge to the battery as the car is rarely used. Is the 65amp a similar size to the 55 and will I need to make any modifications to the mount?
And finally, prices seem to be around ?60 + P&P but higher for Bosch. Are there any other brands I should consider that you think will be suitable?
Danny
Danny
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
GSF and ECP don't stock 55s anymore. I'll probably go for 65 Amps but is it worth going any higher than that?
Mk4 TDi
Mk4 TDi
Bump
Mk4 TDi
Mk4 TDi
I'm pretty sure you need different hardware to mount the 90A alternator, 65A is the biggest which fits in the stock location. If you bought a 90A alternator from a Mk2 Golf or something, you'd need the cover which fits over the water pump, and different water pump bolts, too. Maybe more stuff too?
Thanks Paul.
65A it is then. Have been offered a 90A from a mate's old passat but think I'll pass now if it involves altering mounts/brackets etc;
Mk4 TDi
Mk4 TDi
![sweetmk1dub in the usergroup ‘Paid Member’ sweetmk1dub in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![sweetmk1dub in the usergroup ‘Old timer’ sweetmk1dub in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
i have a 65A bosch jobby in the garage from my old mk1 gti, i used to work at a place that reconditioned them so i know its a good one, was on the car for about a year before i stripped it for spares, yours for ?20 if you fetch it. karl.
Thanks for the offer Karl but I've just bought one from Crazyquiff.
Danny
Danny
Mk4 TDi
Mk4 TDi
no worries, when i finally start putting mine back together i will most likely have to visit "the quiff" for some parts myself
