16v kr conversion wiring loom
m. salt
I bought a mk1 gti with a half fitted kr lump im now struggling with the loom, im missing the isv control box?? do i need this??? also i cant seem to find your conversion loom guide??
Its the later blade fuse box..
Cheers phil
Mk1 golf gti 8v slow resto mk2 golf gtd Mk 4 golf tdi B3 passat gtd (stripped and scrapped) Suzuki Sv650s(sold)
i havent made a full on guide for this, paul made one its stickied, and i have wiring diagrams for the kr in my sig g2krecuce1.pdf
So what does the avv stand for???
Also is there much i need to do to the loom or is it just a plug and play??
the pre90 mk2 looms plug into the mk1 blade fusebox, but its on the opposirte side of the car so lengths are all to pot. but its not hard to unwrap, tweak then tape it up
Well if its just plug and play i may have a few issues to overcome.. i have no fuel pump + also a load of other stuff on the other loom,dip beam, heater blower rear screen heater… Best get my test light out
Im struggling to find a aav or a isv control unit, but if i can start without them, at least i can hear it run..
I also need a lower timing belt cover…
do you know of any washer pump that i can fit so i can run my front and rear washers from the rear bottle??
Phil
you'll want a non-return line in the front hose plus you'll have to fiddle with your wiring a bit! need to make it like mk2 golf, run both C/9 and E/7 to the rear pump.
basically, remove the earth for the rear motor, drag the front motor wire back in and then connect that where the rear motor earth was. put a spade on it inline so you can remove the lighting loom if you need to in future without cutting anything. it may even have a spade on it already in fact
Cheers for all your help, I will upload a load of photos soon as the little yellow beast is staring to look quite cool..
Phil
