Wheel Options
(In Topic #167593)
1.3 Driver
Couldn't really find a category to put this post in so hopefully this is suitable.
Looking at changing the wheels on our Golf and wanted to ask what pattern/specs the mk1s have that I need to match to new wheels? 4x100 pattern I believe but any other numbers I need to take note of?
Also, any suggestions for new wheels? Like the Teledials in black but I know these need adapters. Do newer VW wheels fit mk1 golfs?
newer vw have larger pdc such as 112 and have usually moved to 5 stud also.
i think Porsche adapters are 5x130 to 4x100 to fit, i think 20mm thick is average.
i was going to get teledials myself and it seems a lot of folk go for a staggered set up.
i pressed the little red button
I really like the teledials, the staggered looks pretty sweet!
http://www.upownersclub.co.uk/forum/uploads/188/mk1up.jpg
They have the same pcd and centre bore so will fit a mk1, but I'm pretty sure they are 16x6 et43 so would need spacers as the offset is a little high for a mk1, and you'd probably need quite low pro tyres to make them work, not sure if much goes into fitting 16s but I think quite a few people do it so should be alright if you like the look
'83 formel e
